Re: Re: Re: Cleaning a Gas Tank
Posted by Don(PA) on August 03, 2000 at 18:24:24 from (205.188.199.204):
In Reply to: Re: Re: Cleaning a Gas Tank posted by Brian Schmidt on August 02, 2000 at 19:41:43:
I just finished cleaning a tank off a 44 M -- it was nasty rusty inside! I had tried course sand and agitating it on a chain rig in the shed, but it was so bad that I got out only the loose stuff - a couple of cups! I then followed Spencer Yost's suggestion of using roofing nails (it sounded strange, but it was effective!). Just dump a bunch (I probably had 5 pounds in that big tank) in and agitate the heck out of it. Since the gas cap was already pretty beat up, I wnet ahead and used it to seal the opening - don't want nails all over the farm! A pipe plug closed off the outlet where the strainer was removed. The agitation was the problem, as hand shaking while suspended just wasn't sufficient. My Dad made a little rig for the side of another M wheel, and everybody took turns driving it around. CAUTION - THAT TANK STICKS OUT AND IF YOU ARE NOT CAREFUL, SOMEONE CAN GET REALLY HURT -- USE YOUR WIDE OPEN SPACES!!! Also be sure it is tied and bolted down TIGHT or it will wiggle around and fall off - damaging something! GO SLOW! Did that a few times with water, draining and hosing it out with clean water, then using Naval Jelly (phosphoric acid) and water. Keep agitating and when the water gets really rusty looking, drain and flush out. Took me all day! I pulled the nails out with a magnet on a handle -- worked really well. If you keep rotating the tank, they will all come out - just be sure to twist the tank so that the nails can slide down the top of the tank (the baffle is very close to the bottom, but not the top). But when it was finally done, the inside looked clean for the first time in 8 years! Dry it REALLY well immediately, though, or the water will rust the inside -- then let it sit in the sun open for several hours or days... Then apply your Kreem or whatever sealer. As bad as the rust was, it did not leak through! Good luck, and hope however you clean it works out for you. Don(PA)
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
