Re: plowing and wheel space ???
Posted by Dave Sherburne NY on June 04, 2011 at 12:46:16 from (50.48.50.151):
In Reply to: plowing and wheel space ??? posted by Matt (NEIA) on June 02, 2011 at 16:26:50:
Centerline of the tractor to inside of right rear tire should be 27 1/2 inches. If plowing deeper than 8 inches add 1 inch to measurement. Do not use swaybars or anything to keep the plow from moving right or left. It will stay where it belongs if the plow is adjusted correctly. When its in the ground it should set level right to left, and front to back. If the cut of the furrow is to wide or to narrow, there is an adjustment on most plows to point it to narrower or wider cut.
