Re: Farmall A/B fan trouble
Posted by CNKS on June 04, 2011 at 13:13:10 from (216.144.104.128):
In Reply to: Farmall A/B fan trouble posted by old on June 04, 2011 at 13:05:34:
You can probably remove it without removing the radiator, but why? All you have to do is remove the grill, radiator and shroud, the rest is easy. Compared to the H/M the radiator removal is simple. Get a sealed bearing fan. I have them on 2 C's and a Super A.
