Yes, you can split it in front of the transmission. It's not as much trouble as splitting at the clutch. Make sure you don't disengage the clutch while you have it split so you will be able to get the shaft back through the splines in the clutch plate. When you split, you can separate it enough so you can get to the coupling in the shaft and take it apart. then you can roll the rear part back. when you do this, the back part is nearly balanced, so it just takes a shop lift of some sort to steady it as you roll it back on it's own wheels. Make sure the front part is well supported so it does not tip over.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
