Farmall Tractors Discussion Board
Re: Need Answers!!!
Posted by Todd Markle on January 04, 1999 at 19:43:36:
In Reply to: Need Answers!!! posted by Todd Eslick on January 01, 1999 at 18:37:48:
You must be building a pulling tractor. I dont know about an H/350 but I have seen guys take the
sleeves out of an M block and bore them to accept
4-1/4 pistons. See what size your block is without the sleeves, then find pistons that are
about .030 bigger and bore the block to match them. It may take some research to find pistons with the proper height and wrist pin diameter though. Most parts stores have books that list pistons by dimentions. 350 pistons may be close
but you definetly want to bore the block because
the bores for sleeves may not be straight or round.I would think the crankshaft would be the same-they are the same stroke so there would not
be any advantage. I dont know about the valves.
If the 350 valves are bigger any good automotive
machine shop should be able to put bigger seats
in for them. Again most parts stores have books that list valves by dimentions-I know NAPA does.
Hope this helps.
Post a Followup
: Re: Re: Need Answers!!!
