Farmall A/B fan trouble The answer
Posted by old on June 04, 2011 at 15:43:33 from (209.86.226.56):
Well I have found out you can not remove the fan with out first removing the radiator due to the fact the fan shaft is to long to be able to clear the mount so yep I pulled the radiator off of it
