Re: 1967 806 - no hydraulics
Posted by Owen Aaland on June 04, 2011 at 17:39:23 from (216.47.33.198):
In Reply to: 1967 806 - no hydraulics posted by wkb352 on June 04, 2011 at 16:51:08:
The most likely cause is a failure of the IPTO hub and shaft/gear in the back of the clutch pressure plate assembly. If you remove the cover under the clutch you can see the parts in front of the release bearing. Make sure the shaft and hub are turning with the PPA.
When the splines wear out they usually make noise for a little while but if run enough they will quiet down as they splines wear more. The rivets that hold the hub to the clutch cover may be what failed. In that case they will make little or no noise.
