Posted by Janicholson on June 05, 2011 at 12:20:39 from (67.72.98.46):
In Reply to: Re: Help!!! Cuttman posted by ih560 on June 04, 2011 at 09:09:47:
If the switch was rated at 50 amps or more, the alternator would be able to run directly to the battery (Through a fuse link if I were doing it) This would eliminate the constant draw of a One wire system. Some draw such that the battery can be drained to no start, in a month, some are less drain, but more RPM to excite. If a low amp switch was used, a relay could be used to make it work, but that is more complex than a good to go 3 wire. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
