Re: Farmall H stalls
Posted by old on June 05, 2011 at 12:28:53 from (209.86.226.11):
In Reply to: Farmall H stalls posted by REK on June 05, 2011 at 12:22:26:
Pull the drain plug out of the bottom of the carb. Lets it flow for a good 5 minutes. Catch it of course so as to look at it for water/dirt. You should get a good steady flow there. If you do not then work your way back till you find where the flow is stopped or slowed way down. Also make sure when it dies it has a good spark the will jump a 1/4 inch gap
