Re: Farmall H stalls
Posted by Janicholson on June 05, 2011 at 12:33:06 from (67.72.98.46):
In Reply to: Farmall H stalls posted by REK on June 05, 2011 at 12:22:26:
I like old's answer. The cap may just be giving you a false sense of doing something, when it is just time that it takes getting fuel to the carb to run (through dirt) There is a screen in the fitting at the carb that is also often plugged up, and not known about. Jim
