Open circuit voltage on stick welders is as low as 25 volts on some, and as much as 60 on others. 25 is pretty low to cause much of an issue with shock, but 60 is in the range of too much. Measure your volts on several current settings and see where you are. If it has internal shorts or improper grounding, it could be way hot to ground. Measure between the groung clamp and the stinger, and between the stinger and (as John indicates) Mother Earth, and from both electrode systems to the electrical ground. Anything more than 30 volts requires respect. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
