Posted by Pat-CT on June 05, 2011 at 13:19:50 from (68.9.37.25):
In Reply to: Farmall H stalls posted by REK on June 05, 2011 at 12:22:26:
If you do not get fuel flow like what old is describing, check the inlet screen on the carb, possible clogged, Check the fuel bowl for a possible clogged passage, blow it out with compressed air OUTSIDE. Drain the tank, look inside or in the gas that you have drained to see anything that might get sucked over the outlet of the tank. If you see none of these things, You may have a carb problem or a ignition problem.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
