The update kit was a new shaft with square pins rather than round. The one piece gate where the shift rod levers meet the shaft is changed to three pieces. The outer housing where the shift lever attaches was changed so that the slot goes all the way through to the outer end. That allows assembly without removing any pins from the shaft.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
