Re: Farmall H stalls
Posted by El Toro on June 05, 2011 at 16:19:52 from (108.15.86.54):
In Reply to: Farmall H stalls posted by REK on June 05, 2011 at 12:22:26:
When it quits running pull off a plug wire and check for fire to your plug asap before anything cools. If there's still good fire check the fuel flow to the carburetor. Unhook the gas line at the carb and see if there's a full stream of gas from the tank. Hal
