Re: Farmall H stalls
Posted by Bill in NJ on June 05, 2011 at 16:28:51 from (4.248.91.76):
In Reply to: Farmall H stalls posted by REK on June 05, 2011 at 12:22:26:
You seem focused on the gas cap. Have you tried running with the cap loose? The 'H' is a gravity type fuel feed and the cap might not be venting correctly. The vacuum created could be the problem. The next time it happens, loosen a gas line and see if there is flow. If that doesn't fix it, then I would point at the condensor or coil.
