Re: Farmall H Lower 1st Gear
Posted by Bob M on June 05, 2011 at 20:33:12 from (67.240.171.41):
In Reply to: Re: Farmall H Lower 1st Gear posted by Tyler Jackson on June 05, 2011 at 19:42:45:
Unfortunately, no.
The 9 speed INCREASES ground speed by 40%(?) in gears 1 thru 4 (5th gear is unaffected). It also increases PTO and belly pump RPM by the same amount when engaged.
