Re: Farmall H Lower 1st Gear
Posted by gene bender on June 06, 2011 at 02:33:25 from (207.177.56.53):
In Reply to: Re: Farmall H Lower 1st Gear posted by DeltaRed on June 05, 2011 at 20:32:28:
The ground speeds were between 4th and fifth but you have low overdrive the 2nd overdrive and so on. Very handy for rotary hoeing and pulling wagons to asnd from field and so forth you will lose a bunch of power in ODso they are not for heavy work. Farming has changed bunches we dont harrow and use the rotary hoes and lots of other tasks like yesteryear. The 5-700 bu and up wagons are not for the H maybe empty when they weigh 8-9000 lbs empty.
