Re: Removing transmission cover...
Posted by F-Dean on June 06, 2011 at 07:42:34 from (75.225.1.200):
In Reply to: Removing transmission cover... posted by Stemmy on June 05, 2011 at 21:17:58:
I used the bolt holes for the steering column and the seat to lift mine. You minht have to pry up on it a little to break it loose after sitting for all these years.
Be sure to put a 4x4 or 6x6 under it BEFORE you stick your hands in to check on the gears.
