Re: Farmall C runs rough under load
Posted by Jim Becker on June 06, 2011 at 08:37:54 from (173.57.144.251):
In Reply to: Farmall C runs rough under load posted by astroman1975 on June 05, 2011 at 16:39:57:
I'm going to key in on your statement "it often starts runing very rough" and maybe take a different slant on your problem. Does your engine really run rough or is it simply surging? If it is rough, you need to make sure the fuel and ignition systems are in order before you get into the governor. Maybe you need a tune-up. If the ignition is in shape and the caruretor is delivering enough fuel, the next thing to check is the linkage between the governor and the carb.
With the engine off, unpin the forward end of the rod that connects the governor arm to the carburetor. Push the control lever forward. Pull the (now disconnected) rod back so the carb is wide open. The pin in the linkage should be able to slide back in without moving the other parts. If it doesn't, turn the yoke on the front end of the rod to the longest adjustment that will let the pin slide in. Make sure that link moves freely with no binding.
Only AFTER doing all this, remove, clean and adjust the bumper spring as already mentioned.
