Re: Starting M in 5th.
Posted by Yooper Farmall on June 06, 2011 at 12:34:42 from (141.210.112.16):
In Reply to: Re: Starting M in 5th. posted by Yooper Farmall on June 06, 2011 at 12:20:30:
Variables:
Engine, carb, distrubutor rebuild.
No wheel weights
Calcium chloride tire balast removed
Low compression distillate head
High Compression pistons
Distributior upgrade
