Re: F20 gears
Posted by chris cummings on June 06, 2011 at 15:30:37 from (72.209.175.234):
In Reply to: F20 gears posted by bornred on June 06, 2011 at 05:07:52:
I believe all rear end gearing is the same however there different transmissions that were in the f-20. I had 3 different ones myself. So tire size will matter. the 24inch tires are gonna make it lowered gear and the 36inch and 38inch will be higher yet
