Posted by Athol Carr on June 06, 2011 at 16:17:39 from (115.188.3.223):
In Reply to: Starting M in 5th. posted by NDS on June 06, 2011 at 12:07:31:
In the Farmall H and M and similarly in the W-4 and W-6, 5th gear ratio is 1:1, i.e. straight through as the gearbox output shaft is directly clutched into the gearbox input shaft. The lay-shaft is just revolving without any load unless the pto or hydraulic pump is being used. The only reduction is in the bevel drive and the final bull gears and as far as I am aware were always the same. The W series had a different bevel ratio from the Farmalls.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
