Re: Removing Farmall A Cast Wheel
Posted by d beatty on June 06, 2011 at 19:03:34 from (67.167.73.6):
In Reply to: Removing Farmall A Cast Wheel posted by Stevie J. Mote on June 06, 2011 at 18:37:47:
I have removed them from a Farmall B. I jacked it up then loosened the bolts . I left them in loose to catch the wheel when it broke loose. I used a heavy blacksmith hammer . Mine broke loose after about four good hits. Bolt left loose keep it from chipping the floor or maybe getting you when it comes loose.
