Re: Burning Oil in my H
Posted by Bill in NJ on June 06, 2011 at 19:07:22 from (4.248.91.197):
In Reply to: Burning Oil in my H posted by Minnesotan H on June 06, 2011 at 18:32:36:
Start by pulling the plugs and doing a compression test. You need to do two tests per cylinder. Test each cylinder dry and record the compression. Compare that reading to the spec chart for your engine. Then squirt some oil in that cylinder and do another compression test. If your compression goes up an appreciable amount, your problem is in the cylinder. (Rings, pistons, Cylinder wall wear.) If the compression doesn't go up much your problem is in the head.
