Re: Removing Farmall A Cast Wheel
Posted by gene bender on June 07, 2011 at 03:07:44 from (207.177.56.53):
In Reply to: Removing Farmall A Cast Wheel posted by Stevie J. Mote on June 06, 2011 at 18:37:47:
You need to replace the 6 bolts that hold it leave them a couple rounds loose now spray the area with some wd-40 or something like it. Now go drive tractor around to get the center to break loose from the hub as i understand thats what your problem is getting the cast loose. That cast weighs 147 pluss the wt on the inside so you realy need to be careful as thats a lot of wt to be messing with.
