Re: oil on brake band
Posted by gene bender on June 07, 2011 at 03:17:46 from (207.177.56.53):
In Reply to: oil on brake band posted by pheel on June 06, 2011 at 16:26:34:
It is hard to tell from your description as to which seal is leaking but now that its apart replace both. The pan on the bottom needs to be full as thats the way the gear on the ned of the diff shaft and bearing gets its lube. I replace them first thing when getting a new to me tractor as they usually need either on or both and i always want good brakes.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
