Re: Removing Farmall A Cast Wheel
Posted by mkirsch on June 07, 2011 at 06:10:53 from (64.80.110.74):
In Reply to: Removing Farmall A Cast Wheel posted by Stevie J. Mote on June 06, 2011 at 18:37:47:
You're likely dealing with 300lbs (THREE HUNDRED POUNDS) of cast steel there.
Make sure you wedge the front end so it can't pivot, with wooden wedges. Otherwise when you take this wheel off the tractor could flip over.
It's just rusted on to the hub. A couple of smacks on the backside with a BFH, and it'll fall off in your lap.
