Re: IH Farmall 656 AMP light?
Posted by Bob M on June 07, 2011 at 11:21:49 from (67.240.171.41):
In Reply to: IH Farmall 656 AMP light? posted by Josh Day on June 07, 2011 at 07:10:06:
Josh - The most common cause is a failing regulator. However a failing generator or loose wiring are possibilities also.
Switching to an alternator will cost about the same as a new voltage regulator. If yours is a working tractor that's what I'd recommend.
You will need to fabricate a new (or modify the existing) pivot bracket. The adjustment bracket however will probably work as is.
