Re: 8 Volt Battery in M
Posted by george on August 04, 2000 at 06:35:38 from (209.9.254.221):
In Reply to: 8 Volt Battery in M posted by Convert on August 04, 2000 at 06:14:54:
My understanding is that using an 8 volt in leiu of 6 will not cause any damage. It will, however make the starter motor spin faster.
The generator is most likely only rated to produce slightly over 6 volts, therefore it may not be charging the battery completely.
I wouldn't count on the readings from the in-dash ammeter. Put a voltage tester on the battery terminals with the tractor off. You should read at or slightly above the battery voltage. With the tractor started, the generator would normally be charging, therefore the voltage should be higher. If not, check the voltage regulator.
The generator can be rewired by a shop for little money if it is defective. Send the regulator along with it...that way they can test the entire system.
Post A Followup
: Re: Re: 8 Volt Battery in M
