Posted by Owen Aaland on June 07, 2011 at 13:44:55 from (216.47.35.39):
In Reply to: Farmall 460D Rowcrop posted by John Athey on June 06, 2011 at 07:20:44:
The shaft coming out of the steering valve was designed to have the front yoke of the universal joint slide on it to allow fore and aft movement of the valve. Over the years many of these splines have worn out and the yoke has been fastened either with a pin through both parts or a set screw in the yoke. It will work OK when this is done IF you make sure there is enough movement in the steering linkage all the way back to the steering wheel.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
