Posted by Jimb2 on June 07, 2011 at 15:29:06 from (99.240.236.11):
In Reply to: Re: 574 very sick? posted by TimWafer on June 07, 2011 at 13:26:11:
Hi Tim, my brother has a 684 same D-239 German Diesel as your 574. It always leaked a little crankcase oil at the clutch inspection plate. If we were using it in one field that had a side hill it would leak about a quart of oil in 10 hrs. At about 7,000 hrs we had to do a clutch, pressure plate, release and pilot bearing job. When we took the flywheel off to have it turned, we noticed 3 of the 4 rear main bearing oil seal cap screws were loose. We torqued them to spec and it has not leaked a drop since and that was about 10 years ago. Hope your cap screws haven't backed out into flywheel.
Re vibration and noise, as someone else said probably a clutch or pressure plate spring broken or clutch release bearing but release bearing should not turn unless clutch is depressed and the same with pilot bearing.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
