Re: M fanbelt removal/replacement
Posted by The Red on August 04, 2000 at 07:16:18 from (206.246.187.2):
In Reply to: M fanbelt removal/replacement posted by John on August 04, 2000 at 06:50:23:
John if the belt is completely shot, just cut it off. Otherwise pry it off the lower pulley than maneuver around the fan blades. The back side of the lower pulley is threaded and can be adjusted for tightness. While the belt is off I recommend you get the adjustable hub working smoothly. Don't be surprised if it is cracked.
Post A Followup
: Re: Re: M fanbelt removal/replacement
