Re: F 12 rear wheel clamps
Posted by Dave Allgire on June 08, 2011 at 04:44:05 from (96.35.219.38):
In Reply to: F 12 rear wheel clamps posted by Bill in NJ on June 07, 2011 at 12:33:10:
There are two different clamps. 5368D is the inner clamp and 5369D is the outer clamp. The inner clamp has two "feet" on it. The outer only has one. Assuming the hub of the cast center is toward the outer end of the axle, the inner clamp with two feet when tightened keeps the wheel in alignment with the cast center. The outer clamps, when tightened evenly all the way around, center the rim on the cast center. Tighten the outer clamps in a criss-cross pattern and you will end up with even spacing between the rim and the cast center.
