Re: stuck brakes
Posted by The Red on August 04, 2000 at 08:20:52 from (206.246.187.2):
In Reply to: stuck brakes posted by little red man on August 04, 2000 at 07:30:02:
Need a clarification. Are the main wheels not turning or are the brake pedals froze up and you don't have brakes?
Anyway, unhook the spring and the yokes that operate the brake levers. There are 5 bolts that hold each cover to the frame. If the brakes are frozen so the wheels don't turn, you will probably have to remove the little brake arm on each side and pull the covers off the band shaft. A good half day job and lots of penetrating oil.
Post A Followup
: Re: Re: stuck brakes
