If you use an elec switch, to get the most bang for the buck and utilize all the advantages one has to offer, I suggest you match it with a high energy coil (that suits the switches current rating) also. Some (but NOT necessary) run a wider spark plug gap and IF you do that you need to use good quality plug wires and cap n rotor etc. If the plug gap isnt increased over stock, however, there shouldnt be any extra wire or HV arcing type problems.
They are NOT a cure all for other problems and probably dont raise HP much if any at all, but most report improved starting and idleing characteristics.
HOWEVER if they crap out youre screwed versus being able to file a set of points to get back to the shed.
BE SURE AND USE CORRECT POLARITY
It just doesnt seem they are of the quality and durability of modern high voltage high energy automotive ignition systems buttttttttttttt much of that has to with them ALSO no longer using distributors which our old tractor hybrid systems must still use.
Your tractor your choice, some like them others dont, they have advantages AS LONG AS THEY ARE WORKING.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
