Re: farmall C cast #'s
Posted by Cliff S on June 08, 2011 at 16:58:07 from (64.136.26.227):
In Reply to: farmall C cast #'s posted by Lo hp ih owner on June 08, 2011 at 16:36:25:
The Block you Have is a Super C Block and will Accecpt the 3 1/4 Pistons!
This will Give you 133cid and with the Right Parts to go with the Bottom end you Can Acheave Between 29 up to 50+ HP depending what you Want To Do!
I Have Ran This Combo in a Super C On the NATPA Curcut and Won a few in 3250 Div 3 with 14.9x36 Cut Tires!
I Also Have a Tamer Verson in a BN that Runs 13.6x28 Non Cut tires !
Frame weights are Knot Needed unless you plan on useing a Fast Hitch equitment etc and Farming !
You Need Weight Brackets So you can Adjust your weights For Pulling !
Cliff S
