Re: 1066 TA
Posted by Owen Aaland on June 08, 2011 at 23:25:03 from (216.47.33.99):
In Reply to: 1066 TA posted by rustyfarmall on June 08, 2011 at 04:14:18:
Pretty much the same thing. Once you push in the clutch pedal it releases the TA clutch the same as if you pull the lever back. If you go from TA to direct with the clutch depressed the TA clutch still will not engage until you start to engage the main clutch.
