Re: M fanbelt removal/replacement
Posted by Haas on August 04, 2000 at 14:33:25 from (129.37.117.179):
In Reply to: M fanbelt removal/replacement posted by John on August 04, 2000 at 06:50:23:
The waterpump/fanblade pulley is split. There is a hub with threads that adjusts the width of the pulley and thus the depth that the belt runs in the pulley. The threaded hub is secured with a set screw and a lock nut. You will have to loosen the lock nut and then use a screw driver to back out the set screw. The threads on the hub are probably full of rust, dirt and grease which you will have to clean up. You'll need a lot of Liguid Wrench. It'll be easier to work on if you can get the fan shroud out to have more room in there. When I did mine, the radiator was off, so that made it easy.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
