Re: Corroded battery cable
Posted by d beatty on June 09, 2011 at 16:56:25 from (67.167.73.6):
In Reply to: Corroded battery cable posted by equeen on June 09, 2011 at 16:38:49:
When I find a cable in that condition I replace it. I have yet found anything that will totally stop the corrosion. If its as bad as you say it is its not carrying full load.
