Posted by Janicholson on June 09, 2011 at 18:29:37 from (67.72.98.45):
In Reply to: 230 farmall posted by walkman on June 09, 2011 at 16:13:19:
The candidate most likely to be responsible is the head gasket. There is a passage to the valve train that can put oil directly into the water passages. There are few other choices except a crack in the block into an oil gallery from the water jacket. This is not a probable cause. Leaks from the lower end into the water can't happen because the water is pressurized and the oil at that location is not. Best of luck, Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
