Re: Corroded battery cable
Posted by Janicholson on June 09, 2011 at 19:03:53 from (67.72.98.45):
In Reply to: Re: Corroded battery cable posted by equeen on June 09, 2011 at 18:54:38:
Nice!
You could cut the cable insulation until you find bright shiny wire. Then use a crimp on connecter (soldered onto each wire) and shrink tubing to add new same size cable as an extender. Jim
