The electrical system is well grounded (starter, gen, relay, bat cable).
Wiring has been checked against John Nordhoff's troubleshooting guide.
System does increase volts across bat posts when I ground the generator field post to case then jump a wire from the Cutout Relay's BAT terminal to its GEN terminal. In my test, with battery not fully charged, it increased volts across bat from 5.8v with engine running to 6.2 with engine running.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
