Re: more 6 volt
Posted by old on June 09, 2011 at 21:53:33 from (4.245.14.57):
In Reply to: more 6 volt posted by joe300chickens on June 09, 2011 at 20:29:56:
8 volt battery is a band aid fix for other problems and a good 6 volt charging system will only keep an 8 volt battery at around 7 volts so in the long run your not much is any better off and when was the last time you found a battery charger that would charge an 8 volt battery. Shoot it is getting hard to find one that will charge a 6 volt battery now days
