Re: international 130 hydraulic
Posted by Janicholson on June 10, 2011 at 06:13:53 from (199.17.6.81):
In Reply to: Re: international 130 hydraulic posted by GRAPE-DRANK on June 09, 2011 at 21:00:12:
The word Priming is a general term meaning putting a task or machine in a condition that sets the stage for action.
Priming a pump (this case) is filling it with working fluid so that it draws new fluid in and pushes fluid out into the working valves.
Priming for paint is putting on a layer of paint (primer) that adheres to the base material better, or more tenaciously, than the finish coat, and helps the finish coat adhere to it.
Priming a shot shell puts a new ignitor into the brass of the empty casing to allow eventual firing.
Hopefully this makes sense! I smile, Jim
