Re: Corroded battery cable
Posted by Ludwig on June 10, 2011 at 06:49:08 from (68.162.248.195):
In Reply to: Corroded battery cable posted by equeen on June 09, 2011 at 16:38:49:
If it starts good electricity is getting through and its probably not the cause of your charging problem.
