Re: changing tire size
Posted by Delta red on June 10, 2011 at 17:36:11 from (97.124.213.236):
In Reply to: changing tire size posted by Howard Junkin on June 10, 2011 at 09:10:29:
you will have some speed reduction-but not a lot.you will have more torque to the ground on a HARD pull.However,you may "loose ground" at a tractor pull due to a smaller foot print-unless you weight it(fluid/cast-or both)to compensate.
