Re: OT NH 489 haybine - anything to watch out for?
Posted by garrry on June 10, 2011 at 20:36:12 from (69.179.16.178):
In Reply to: OT NH 489 haybine - anything to watch out for? posted by Marty from MN on June 08, 2011 at 19:40:32:
Make sure you check the chain adjustment on the chain that drives the cutter bar gear box often. Some have a spring adjustment to keep them tight, and some just have a block you have to adjust by hand. If this chain gets loose and breaks it has no room to fall away from the sprocket on the gear box. It will jamb, and then break the gearbox shaft. It"s in a hard to get at place, but make sure you check it. New gearbox was $1600 last year. NH will not let their dealers repair this gearbox. as they don"t have the equipment to set bearings correctly.
