Re: Grounding Generator
Posted by Janicholson on June 10, 2011 at 20:54:49 from (67.72.98.45):
In Reply to: Grounding Generator posted by equeen on June 10, 2011 at 19:38:26:
The grounds you have are correct. There are only chassis grounds on a Farmall.
Does your generator charge the battery if you are running at 1/2 throttle and ground the F generator terminal with a jumper?
If it does, that is a great place to start. If you are on line answer back. Jim
