I.H. Cub Loboy Serial #13218U - need help
Posted by AR Martin on August 05, 2000 at 13:29:31 from (24.128.190.214):
I purchased this tractor running great. After it sat a while it now only runs if I mist the carb or air intake with gas. I think it has an intake manifold manifold leak and will not pull the gas/air mixture through the updraft carb. I cxannot find the leak. I have several implements with it and all the Hydraulics work. Where in eastern Massachusetts can I get it worked on? If not Mass what about NH or Maine? What year is it?
What is it worth and do you in the know think it is better to sell it to a collector and buy something newer to use at my camp up north. (Mow and till fields and drag wood main needs) Any info greatly appreciated.
Post A Followup
: Re: I.H. Cub Loboy Serial #13218U - need help
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
