Re: F-12 Brake seals
Posted by oldiron29 on June 11, 2011 at 03:17:47 from (69.112.87.249):
In Reply to: F-12 Brake seals posted by Tom Fleming on June 10, 2011 at 18:35:58:
Tom, The shaft seal is what leaks most times.
I have changed most I have ever taken apart.
Never changed actuator shaft felt, it seems to be high enough it doesn't get much oil on it.
Basic pull out old seal install new with greese on back side. oldiron29
